Results 1 to 11 of 11
Thread: I love this pic
    naugatuck connecticut
    some one post this one here remmber i like it.
    SE Michigan
    Wink
    Sure is fun changeing the shaft and bearings in those.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    burlington county n.j.
    sure am glad i don't work on that stuff.
    Fort Worth, TX
    We have two like that here in my building, one larger than the other. Both return air fans. One on a freq drive, the other not. Showed the bigger one to my wife one time during a tour and she freaked. That and the fact that I can walk inside the return side of the air handler that return fan is attached to (I'm 6' 4") with tons of headroom to spare had her kind of spooked. Funny how the same piece of equipment affects people different ways.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Oct 2005
    I would call that big SOB a WidowMaker for sure. A belt guard would be nice to keep from getting sucked in.
    Oct 2005
    Thumbs up pic does size matter
    That’s a baby you should see the ones you can move the whole family into. Some the unit was installed then the concrete walls. Had to do shafts and bearings several times on these types one time the large unit was suspended in the air in the mechanical shaft what fun that was. $ Would be happy to do yours just send a email
    Oct 2005
    whats the hp on the motor?
    Jul 2001
    Gold Coast of Connecticut
    Belt Gaurd?
    You had best not be in the blower compartment with the thing running.......damn!
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Nov 2005
    cairo -egypt
    Lightbulb
    ASTEAY BAGK MY FREIND .......IT NEED BILT CAVER.
    GOOD JOB..
    Together we can improve our business
    tidewater, va
    Sherrycool,
    Masaa' al-khayr and greetings from the US. Anti min al-qaahira, fee Misr? I was in Eygpt many years ago. It is a great place. Welcome aboard at HVAC-Talk.com!!!!
    404
    Oct 2005
    very impressive
    once seen an air handler about that size had an inhouse guy at the mall open the door without turning off the disconnect oops sucked in his little craftsman rollaway toolbox come to find out he had earlier in the week jumped out the door saftey to enable it to run$$$$$$ big dollar fix
