Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    SW FL
    Thumbs up Oregon Scientific link
    Quote Originally Posted by pinoyclass View Post
    I have an old tstat just laying on a table and its measuring the humidity at 35% but the air still doesn't feel as comfortable as the old system did.
    On the other hand they are greatful their electric bill is 150 dollars on avg cheaper.
    You may wish to check whether 35% R.H. is accurate?!
    http://www.oregoninstruments.com/Ore...onitor.product
    Designer Dan
  2. #28
    http://www.honeywell-thermostat.com/...l/TH8321U.html
    And lower the fan speed to 350 CFM per ton
    Aint no way, they'd be freezing.
  3. #29
    SW FL
    http://www.oregoninstruments.com/Ore...-Clock.product
    Nice for temperature, but NO R.H. measurement.
    Designer Dan
  4. #30
    Aug 2011
    Columbus, Ohio
    BaldLoonie-you called it a good match. I'm assuming you checked on it. Is the resulting tonnage still at 5 ton?
  5. #31
    SW FL
    Smile Relatively speaking about R.H.
    Quote Originally Posted by rickboggs View Post
    I am certainly NOT freezing in the summer when my house is at 38% R.H.
    R.H. is relative to Temperature.
    Designer Dan
  6. #32
    Quote Originally Posted by dan sw fl View Post
    I guess you can say humidity is relative.
    Ok, ok, that was dry.... 38% I mean.
  7. #33
    Feb 2011
    Tampa, FL
    I put the device outside and it was showing humidity of 42%. There is no way that's correct here in Florida. I'll have to find another device to measure it.
