Results 14 to 23 of 23
    Originally posted by teigo
    Quick question regarding return duct for High velocity system. Can you have to much return air. Or is more return better to service as many rooms as possible with return duct work. Thanks
    M
    [Edited by dash on 10-30-2005 at 11:09 PM]
    Apr 2002
    More returns equals more resistance in the duct system,which is fine if the ducts are sized properly.
    dash, just trying to follow what you are saying. You mean more returns as in more extensive return duct work, such as a return from all rooms but bathrooms/kitchen etc would mean more resistance?
    More resitance as opposed to 3 feet of duct to a central return grille?
    http://www.ductstrap.com/
    I
    [Edited by dash on 10-30-2005 at 11:10 PM]
    The reason I ask is that I requested a return duct to the only room in the home that didn't have a return duct in it. I'm just not sure if you can have too much return air since it wasn't initially spec'd. The other three bedrooms are serviced by a separate High velocity unit and they all have return ducts although smaller sized.
    Are they Unico, or Space Pak systems?
    Unico,
    If you have them add the return, make sure they check the static pressure in the supply, and adjust the static plate if need be.
    I'm pretty sure that unit is 3 ton and has 18 supply ducts. I do have concerns with the supply duct work. The supply line go approx 30" than does a 180 over the airhandler to take a sharp 180 back the other way. Any concerns here. The work seems tight but the duct planning concerns me. The main supply line runs about 50 feet. Starts out 9" reduces to seven inches for about 20' of the fifty at a 90 degree angle.
    Thats some what typical duct work for Unico systems.
    Thanks, beenthere for your help
