Results 1 to 4 of 4
    Dec 2008
    Howell, MI
    colonic for brazed plate
    Have a 10 ton thermalcare that is running about 15 degrees approach, any success stories on cleaning one?
    Jul 2009
    In a mechanical room....
    I would firstly call the mfg and see what they have to say.
    “It takes courage to grow up and turn out to be who you really are.”
    - E.E. Cummings
    Aug 2010
    Memphis
    Quote Originally Posted by chrishvacman View Post
    Maybe circulate acid through it but I would deffinatily check with manufacturer first
    Jun 2007
    Here. I'm right here i tell you!
    If its stainless do NOT use HCL!! The best I have seen to descale stainless is sulfamic acid. The chlorine in HCL will pit the metal. Check with a water treatment specialist and the MFG to confirm.
