Results 1 to 13 of 14
    Jan 2011
    Cannot Log into Platform FX20
    Hi Guys. I ordered a new FX20 from JCI, but I couldnt open the platform
    1. I changed the IP address on my PC to 192.168.1.05, and subnet mask to 255.255.255.0.
    2. Connect FX20 via ethernet, and open workbench to put in default IP 192.168.1.149. Credential jci, explorer
    But it keeps asking for Credential.
    All the lights look fine. I havent tried serial shell mode yet. I am sure no one touched it before me.
    I am only new to JCI's FX20/60. Any input will be appreciated.
    Leo
    Northeast
    Just the simple stuff at first. Plugged into the primary port on the FX? Try
    Ping 192.168.1.149. Then try a Sniffer like wireshark. Cable Good?
    Then there is always the serial shell, but the above will most likely find the problem and should only take a little time.
    Bill
    Dec 2006
    If it is asking him for username and password, then I would think he has the correct IP address. Sounds to me like the platform credentials are not at their defaults. Instead of using jci explorer, use tridium niagara. Or maybe you left caps lock on?
    Oct 2009
    did you try to sign in with a browser to the station?
    try username: admin
    password: *blank*
    Apr 2011
    as said he cannot login to the PLATFORM, not the station
    if the default Johnson credential doestn work, then its tridium for user and niagara for passw
    Jan 2011
    Quote Originally Posted by Igotworms View Post
    try username: admin
    password: *blank*
    it is a new jace uncommissioned. there is no station running.
    Apr 2011
    Hmm
    Did you try to the credentials we told you to? Would help us to help you more if you could followup!
    Jan 2011
    Quote Originally Posted by martinsbt View Post
    Surely I am gonna try it on Monday. Will keep everyone posted. Thanks a lot
    Melbourne
    ... just reset it via the console
    1 + 1 = 3 ( *** for very large values of 1)
    ...everybody wants a box of chocolates and long stemmed rose
    Be brave. You cannot get eaten by an imaginary tiger.
    Northeast
    Quote Originally Posted by leoxxl View Post
    There is a default station running when they ship. JCIstation I think. Try the suggestions and you should get in.
    Bill
    PS Sorry I missed that you were connected in my previous post.
    Mount Airy, MD
    Jul 2011
    NC
    I believe you can go into shell mode and reset platform authentication If I remember correctly. If not I know you can return everything to default settings.
    Apr 2011
    Quote Originally Posted by MrBill1979 View Post
    MrBill is right! connect in serial shell mode (dont forget to set the jumper on the FX and reset power on it! defualt baud rate is 115200) and while booting up it will ask you to press the escape key to reset platform credentials! once done you will be able to get into the platform using tridum as user and niagara as passw
