Thread: t-stat question
    Question
    hi guys . i need a programable thermostat for heat only . i cant find one. i guess they are all for heat and cool. do they make them for heat only? and also can anyone tell me about ritetemp t-stat model no 8022c are they any good or should i go for a honeywell?
    Rochester, MN
    They pretty much all have the heat/ cool switch.. it will still work for the heat only system.. just 2 or 3 less wires to hook up.
    Ritetemp are ok, but you are far much better to go with the Honeywell.
    Vision pro 8000 series, in the installer set up, you can change it to heat only and it won't show the cooling buttons.
    Apr 2003
    Most of the new Honeywells have a heat only setting in the installer set-up.
    (5000, 6000, 8000 series)
