Results 1 to 13 of 14
Thread: boiler
    Nov 2001
    westchester ny
    whats the best boiler on the market
    burlington county n.j.
    the one properly sized and installed.
    and does not break.
    CHICAGO SUBURBS
    As stated many times here, go with a good..... make that great contractor and use his prefered brand. Most heating equipment that you'll here people bashing was not the fault of the brand at all. The fault is shared between the poor installation and the costumer with a bad case of walmartitis.
    Some people swear by me and some at me
    Jan 2005
    Perth - Western Australia
    boilers have improved so much. i agree that the install is what makes the difference. consider honeywell boiler reset & a good thermostat.cheap isnt the way to go, you will pay more in the end
    Nov 2001
    westchester ny
    best name brand, hightest eff.,best qualities
    PA/DE area
    What'cha BURNIN????
    It's NOT the BRAND,it's the company that installs it!!!!!
    Nov 2001
    westchester ny
    150000 btu gas
    Jul 2002
    NY
    Like said before it's the install that counts. I myself like Crown.
    Not what it use to be
    Weil McLain Ultra, Peerless Pinicalce, Munchkin, any of these will be high eff, and quality.
    PA/DE area
    I agree with been there,with gas prices we have really been pushing the ULTRA from Weil Mclain,NICE, i think Pinacle is Munchkin with green paint.
    Oct 2005
    Buffalo
    Confused
    Isn't true that the high efficiency boilers tend to fail sooner (lighter construction), require more maintenance and actually do NOT deliver the advertised efficiency levels unless right conditions (i.e. lab) are present (something about temperature of water when returning back to unit having to be cooler).
    Eager to learn, willing to teach, reluctant to admit defeat.
    Jun 2002
    Bemidji, Mn
    Gas?
    Currently my vote goes to Munchkin. I actually put one in my Shop for the infloor heat this weekend. Quiet, I believe the most efficient out there.
    Now if your looking for an electric Boiler, I would recommend Electromate Industries.
    However there are many others out there also that do the job!
    Installation as always is the key. I enjoy installing/Servicing Boilers. I do not enjoy ductwork
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    You won't get 95% AFUE running 190°, still get 88 to 90% SSE, can use true outdoor reset, don't have to maintain high water return temp when its 45° out. Haven't had excess failures so far.
