Results 1 to 13 of 15
    Oct 2005
    I require a furnace with 119,000 btu output which wold be about 140,000 size. Does anyone know who makes this size with variable speed 2 -stage. I currently have a Carrier which works great but they do not go this big.
    Thanks for your help
    London Ontario Canada
    Brian
    Rochester, MN
    Has a manual J been done to the home? Must be a large home if you really need something that big!
    Oct 2005
    It is 4100 sq ft (one floor) plus the full basement.
    burlington county n.j.
    Lennox G61mpv-60d-135 132,000 input, 122,000 output. 94.6 afue, 2stage v drive
    Oct 2005
    Would another option be a small boiler with hot water coil in a small Air Handler or would this option be too expensive?
    Is your system zoned?
    Have any improvements been done to the house since the old furnace was installed.
    Has a load calc been done.
    Oct 2005
    The home is not zoned.
    It is a brand new home and the footings are now poured only.
    I require 118,000 btu output for heating.
    Feb 2005
    Toms River, NJ
    Ruud makes a 80% two stage 150,000 btu input. I dont know if they offer an ecm motor for it or not.
    Dave in NJ
    You plan on heating a 4100 sq ft house with one forced air system with no zoning????
    That sure wouldn't be on my list of desirable ways to heat that size house.
    Then your in luck.
    You don't need a 118,000 output furnace.
    You need 2 furnaces.
    Use 2, 2 stage furnaces with VS blowers.
    What size a/c does your house require.
    Oct 2005
    House required 3.5 tonne for a/c.
    Apr 2004
    First off you cant twin furnaces with VS motors, sorry to say and I am with the others, it simply would not be good application to install one system for this home, even zoned. I mean if you have to twin furnaces to get capacity why not just have 2 systems and allow them to operate independantly. The installer would almost have to have a screw loose to suggest one system for this home.
    Most brands have 90% with 112 to 115,000 BTU output. OK, so that's just a RCH undersized. So on the coldest morning of the year the temp drops to 68 or 69. Big deal. As pointed out, Rheem has 150K 80% with 120K output if you want 80%.
