Results 1 to 13 of 22
    Jan 2010
    KALA-016E TAC 800
    Anyone know the capacity @ medium temp using R134a ?
    Las Vegas NV
    Here's the capacity when used in a Copeland "C" line unit.
    10,230 btuh @ +20 SST @ 90 Ambient
    11,350 " " "
    Jan 2010
    Quote Originally Posted by powell View Post
    11,350 " " "
    Thanks powell
    And what is the "C" line ?
    This compressor is runinng 3 Russel evaporators in a floral display.
    Russel model # WE 18-55
    5500 btur @ 10* TD
    6600 btur @ 12* TD
    3-front glass doors & 1-end glass door.
    What's your thinking ?
    Thanks,
    VTP
    Las Vegas NV
    Thanks powell
    Sorry for the tardy response, I had to wait for my AOP clearance.
    The C-line is/was a popular Copeland unit that I've used for years to establish the approximate buth's of a semi-hermetic compressor. You'd recognize them, they have two horizontal receivers mounted under the compressor and they're built like a tank.
    5500 btur @ 10* TD
    6600 btur @ 12* TD
    Thanks,
    VTP
    The unit and evaps are matched good. It equates to about a 7.6 TD for a 38 degree box. That's good for maintaining the required higher humidity in a floral box.
    Without knowing the box dimensions I can't speak for the btuh capacity required.
    Winter Haven, FL
    The "c" line is commonly referred to as a "pontoon unit". Like the boat. Its good for selling ots of refrigerant.
    Jan 2010
    I here ya Joe
    When i walk up to those type of units my jug starts to scream
    Jul 2000
    Cuenca EC
    Somebody at Copeland was on the ball when they designed that unit oh so many years ago.
    Those twin receivers made for excellent structural rigidity and allowed for a lower profile.
    Also, because the receiver diameters were typically under 6", they didn't have to ASME Certified and inspected vessels....which equated to a boatload of cost savings.
    Best of all, that parallel design actually worked.
    Jan 2010
    Thanks again powell.
    They are not using the box for flowers so the TD is not so important.
    Form what i'm told the last coil has a tendacy to freeze.
    Those coils have a total capacity of 1.5 ton and your saying that compressor is less then a ton. So i'm worried about that.
    I'll get the box size for you to see what you think.
    Thanks,
    VTP
    Jan 2010
    Quote Originally Posted by icemeister View Post
    icemeister,
    These condensers sure hold a large charge.
    Do you think that was for long run remote setups ?
    Monmouth Junction-NJ-USA
    I service a LAC-3 3 hp Low temp with the dual receivers underneath. A lot of refrigerant!!!!
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Sep 2006
    Chicago
    Attachment 200872
    "The pontoon"
    Jul 2000
    Cuenca EC
    icemeister,
    Large receivers were pretty much the standard years ago. Those were the days when quality and suitability for an application really meant something.
    When I started out, most supermarkets were still conventional, single compressor systems. It was typical for a 3 HP unit to have at least a 40 lb receiver, a 5 Hp might have a 60 and a 7 1/2 could have a 100 lb or larger.
    Today, it's tough to find a stock unit with anything close to that kind of pumpdown capacity...except for the C-Line Copeland.
    Jan 2010
    icemeister,
    Do you know of a way to figure the capacity on these receivers ?
