Results 1 to 10 of 10
Thread: question
    is there a reason why cold air is coming out from the return air vents. when the furnace is on . its not my house. i have steam heat. its my mother in-law house and she live too far for me to check it out .. i dont know to much about furnace but im willing to learn thanks guy..
    [Edited by green_apprentice on 10-26-2005 at 10:32 PM]
    Senior Tech Guest
    Ill bet they're in the ceiling?...Remember cold air falls, warm air rises.
    do you mean the way the ducts are run?
    Mar 2002
    Gaylord, Michigan
    Possible that a makeup air duct has been connected to the return trunk. Maybe you are feeling a draft from that?
    if it isa make up duct can it be fix to the point were she wont have cold air comming out.. thanks
    Mar 2002
    Gaylord, Michigan
    If it is a make up air causing the drafts, Skuttle makes a damper that should fix the problem. Though I doubt that it is, after re reading your original post, you said when the furnace is running. Could be improper ducting.
    Is this house on a crawl space? If so, could also be return air ducting not sealed, or has openings...allowing cold air to infiltrate.
    [Edited by Christheheatingdude on 10-26-2005 at 11:06 PM]
    furnace is in the basement. supply vents are on top of the space return vents are in the bottom.
    Does she have a zoned system,common problem with a bad design and zoning.
    no zone dash.
    Oct 2005
    jiandsu province in china
    also i want to know
