Results 14 to 17 of 17
10-27-2005, 07:44 PM #14
Professional Member*
- Apr 2005
- new jersey
- 749
with the cost of fuel nowadays gas ,oil,maybe electric as well.INSULATE ,INSULATE
10-27-2005, 07:53 PM #15
hy not just get a temparary above ground tank and use it for now. this will take the presure of you all the way arround. you will also gain some time to find a qualified contractor that wil give you the best job he can. you will also have time to insulate even if you do it your self it is better then not at all. above ground temp tank shouldnt cost that much and the oil co should have no problem giving you oil
10-27-2005, 11:13 PM #16
Tin made a very good point bout the temp tank.
10-28-2005, 01:15 AM #17
- Feb 2004
- Pacific NW
- 522
What are Ontario Hydro kW-hr rates now - 5.8 cents or so, even after recent increases as a hidden tax?. After the insulation, consider that a heat pump may be the way to go -- no idea what Canadian NG prices are going to do (up?), but way up at US hubs. . .There are a bunch of threads showing advantageous cost comparisons even for -20C weather, esp. for > $12 MBtu NG. .
