Results 14 to 26 of 54
    Split and wash out the "inside condensor". Pull the top off where the condensor fans are located. Set the whole condensor fan assembly on the top of the unit. Thats why you have all that extra condensor fan wire! On the end of the condensor will be some screws that are holding the condensor in place. When you remove the screws there you will find maybe 2 or even 3 condensor coils that are zip tyed together at the return bends. Seperate the coils and wash them out. They are fairly flexible. Two men are required. After you find the dirt blanket on the inside take a picture of it and post it. Then everyone will know what stops a Trane.
    Jun 2008
    NW Florida
    Quote Originally Posted by jdservice View Post
    Could be. I have had to do that before. Dang Tranes. If it aint that must be a restriction upstream of sight glass.
    Wisconsin
    Quote Originally Posted by Joe Harper View Post
    The question is are both condenser fans spinning in the same direction?
    one may be spinning backwards, where it has a bad cap, or the fuse is blown (its the screw-on ones on the right side of the control panel).
    If one of those fuses were blown neither of the fans would run.
    Buy American! The job you save may be your own.
    Feb 2011
    colorado mountians
    split the flippin coils and quit messin around
    Wisconsin
    Did you change the filter/drier? Did you look at the temp drop across the drier?
    Dallas ,Texas
    I've had pretty good luck with these RTU's usually fixes them when you clean the coils like you are saying. Actually kinda makes you think you accomplished something too.
    UA 100
    It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
    Why do we think it is dirty coil or bad fan motor or bad blades?
    He said he has 23 degrees subcool.
    23 DEGREES SUBCOOL.
    I don't get it. Maybe I miss something since it is trane unit.
    Dec 2009
    northeast pa
    your unit is under charged.Go by superheat for txv not subcool.
    Mar 2009
    Hollywood, Florida
    Quote Originally Posted by tech93 View Post
    huh.....
    Winter Haven, FL
    Idk...maybe that's how they do things up north..??
    Mar 2009
    Hollywood, Florida
    Hmmmm. I wonder how far North?
    Wisconsin
    I recently took 182 lbs of extra refrigerant out of a chiller that was possibly charged to superheat. That was tripping on high head too?????
    Dec 2009
    northeast pa
    On a txv system superheat not subcool subcool for piston. should have 12degree superheat 10 to 11 sucbool . he system was converted to txv on a trane and said it was a single coil with means like 10 to 15 ton
