Results 1 to 6 of 6
Thread: software
10-26-2005, 01:46 PM #1
- Oct 2005
- Kennewick Wa.
- 18
Can anyone turn me on to a good , inexpensive, easy, quick heat/cooling load calulating software. Nothing that would take more then 15 min to run for a small rambler home 1200sf lets say.
Maybe something that would be able to even do small commercial applications?
10-26-2005, 01:54 PM #2
Click on the red tab above this message.
Up a little and to the right.
"HVAC-CALC"
There it is.
It might take a little longer than 15 minutes, though.
10-26-2005, 02:17 PM #3
- Oct 2005
- Kennewick Wa.
- 18
software
Thanks as you can see this is a brand new site to me.
10-26-2005, 02:23 PM #4
Be sure to buy two copies... he needs the cash.
It was developed by the man who built this site and he has 39,000 mouths to feed !
10-26-2005, 02:23 PM #5
- Oct 2005
- 29
As a HO, I'll recommend it as well ref man2. I did my own using the software (about 30 minutes) and was within 5k BTU on loss and gain of two done by the pros. It showed me that my 100K furnace could be replaced with a 60K.
10-26-2005, 02:58 PM #6
Professional Member*
- Nov 2004
- SW FL
- 5,271
< 15 Minutes O.K.
15,900 BTUh Sensible CoolingOriginally posted by ref_man2
quick heat/cooling load ...
Nothing that would take more then 15 min to run for a small rambler home 1200 SF
28,600 BTUh Heating
Therefore, select a 2-ton Heat Pump of your SEER and MFG choice with 8 or 10 kW electric strip.
Great for those with cheap (<$0.10/kW) electric rate.
Designer Dan
