Results 1 to 4 of 4
Thread: York YK seal oil usage
07-20-2011, 08:29 AM #1
- Jun 2006
- Charlotte, NC area
- 87
I am working with an owner who has a new York/JCI 850 Ton, Variable Speed centrifugal chiller (model YK). The compressor shaft seal is a “wet seal” and I understand that this requires some oil to pass through the seal. York service data indicates that any oil usage under 2 oz every 14 days is acceptable. This seems like a good bit of oil to me.
Does anyone have any experience with these machines? And if so what type of oil usage rate have you experienced?
07-20-2011, 09:13 AM #2
- Mar 2007
- 2
The new style shaft seal on the York centrifugal have an average seal leak rate of 90 ml/month. Unfortunately York officially does not consider a seal to be leaking unless it fills the 750ml bottle in 250 hrs of operation.
07-20-2011, 11:09 PM #3
Professional Member*
- Dec 2008
- Dixiana, AL
- 2,499
08-10-2011, 10:03 PM #4
- Aug 2011
- 7
setrite has it right
