Results 1 to 2 of 2
    Jul 2011
    Coil/Condenser Sizing Question
    I was replacing my 10 seer 3ton plenum coil and 2.5ton condenser with a new 3ton 13seer r-410a condensing unit and box coil. One guy who came and gave us a quote mentioned that we should do a 3.5ton condenser and 3ton coil to get a little bit more cooling for the texas heat. I thought you could go bigger on the coil but not on the cond unit. Thoughts?
    I ran across another thread on here that said it was possible to have the bigger unit, but that its really only economical if you live in a high humidity area. I live in Dallas, so we primarily just have dry summer heat without much humidity.
    Will the 3.5ton condensing unit on a 3ton cooling increase my cooling at all, or be recommended in the Texas weather? It's only about $150 more for the equipment cost, but don't want to waste the money if its not necessary.
    Thank you in advance for your comments.
    Jul 2011
    thread
    Here's the link to the thread I was reading, but it was somewhat garbled and parts of it didn't make sense to me.
    http://hvac-talk.com/vbb/archive/ind.../t-328932.html
