Results 1 to 13 of 16
    42yrs exp is offline Professional Member BM -bad email address
    May 2003
    I was talking to an old hvac friend today, and he said there is a 20 SEER system available. The company he works for is a LENOX dealer. So I am assuming it is the Lenox
    Let's see, How do they get the high 20 SEER?
    1. Larger Condenser,more coils
    2. Two speed Compressor
    3. TXV metering device(EETXV)
    4. Variable speed furnance motor DC)
    5. Variable speed condenser motor
    6. variable pitch condenser blade
    7. Refrigerant 410a
    Is there anything I missed.
    How are they going to go higher. Gee maybe a three story condener.
    Anyone have any info on this?
    Thats pretty much it in a nutshell.
    As I said before, thermally there is not much left, Its now just a matter of reducing watts. So coils are really as large as they are going to get until someone can predict wind or develop a chimney effect.
    Rapid City, SD
    I think I read somewhere on here there's a 22 SEER avalible.
    I'm really starting to wonder if this SEER rating is kinda like the horsepower rating on a dyno. You can really manipulate it to get teh numbers you want (with in reason).
    Oct 2005
    Quincy, Il
    arrr arrr arrrr arrrrrrrr
    Every time subjects like this come up, I get reminded of this job, it makes me laugh for some reason.
    The one on the left is 19 SEER, the one on the right is 10 SEER, both are 2.5 ton units.
    Apr 2005
    Tampa, Florida
    Here's a system which supposedly gets 32 SEER:
    http://www.solcool.net/
    Apr 2002
    Phoenix
    Originally posted by mark beiser
    [B]EThe one on the left is 19 SEER, the one on the right is 10 SEER, both are 2.5 ton units.
    So, SEER is like the metric equivelent of cubic feet.
    May 2003
    Ohio
    "7. Refrigerant 410a"
    Does using the newer refrigerant really add to the efficiency? I don't want to start the R22 vs. 410A debate, but I didn't think that 410a was any more efficient.
    Jan 2003
    How about a variable speed compressor? There is always something else that you can make variable speed.
    Instead of making the heating and cooling systems more effcient, we should be making the houses more effcient. Like better building materials, more and better insulation. If the houses were build better, you wouldnt need nearly as much heating or cooling. I went to an underground house in Arkansas one time, 3500sqft with a 2ton heatpump; Extremely low operating cost. We could also use heat recovery systems like Florida Heatpump makes to heat water with the AC system to elminate the need and cost of operating a Water Heater.
    [Edited by peytonc2682 on 10-26-2005 at 02:52 PM]
    Ever so slightly at ARI conditions. Plus, who wants to dump a bunch of money into R&D for a product that will be obsolete in 3 years?
    Starting against a load with a VS is hard and I am suspect that the inrush amps to charge the capacitors would be huge. Freq drives have been used for years but not any more efficient. But hey thinking outside the box is always good.
    Actually its seer and its' by Nordyne.
    And it make me so happy I could jump up and down and whoop!
    The rifgt size company for the guys who want to stay one man shops and growing at a rate that will allow larger companies to derive benefits from them too.
    Tucson, AZ
    Lay person's question
    Hey everyone,
    I have read this post with interest. Some of you pros assert that there really isn't that much more room for improvement as far as SEER ratings go; or at least that is what I understood.
    I have a question: is it possible that some of you don't see room for improvement just because it's hard to visualize it? What I mean is that sometimes we don't see a possible solution to a problem because we are fixed within a certain way of thinking?
    The reason I ask this is twofold. Although I am not a scientist, I still understand, at a basic level, the laws of thermodynamics, so I believe I might have a basic understanding of the limitations involved in HVAC.
    Nonetheless, my understanding is still just basic.
    On the other hand, as I understand it there are plenty of examples throughout history, of scientists who went against the prevailing paradigm and made advances in science. The super-famous book by Thomas Kuhn comes to mind: "The Structure of Scientific Revolutions".
    Please note that I know Kuhn's ideas mostly from the philosophical point of view, not so much the "hard science" one.
    So I restate my question, as a lay person and in good faith, is there really not a lot of room for improvement?
    Best regards.
