    Oct 2005
    Question
    A customer wants to heat his attached 3 1/2 car garage so that his pet can live there. should the unit have a outside air kit? the home is new and well insulated, and is located in the upper midwest. it will be a natural gas unit.Thanks for your input.
    Apr 2003
    Eugene, Oregon
    Direct venting would be nice, depending on BTU rate and cubic feet of the garage you may not need outside air so long as the unit is at least 18" off the ground. All this depends on local codes.
    Proud supporter of Springfield Millers and Oregon Ducks.
    Oct 2005
    the garage is 31/2 car with 10' ceilings. the unit will be suspended naer the ceiling. units ar avaliable with power venting only, and with power vent and outside combustion air. the home is new and well insulated, and the garage doors are weatherstriped. the area above the garage is living space. we expect to use a 60-75000 btu unit. my question really is because of the pet and tight construction is it best to use the outside combustion air model or is it a non issue? thanks again.
    burlington county n.j.
    if garage is being kept on the cool side i would use a unit made for outside air, less chance of condensation problems.
