    tidewater, va
    Have you guys and girls seen any good applications for the variable speed air handlers in HEAT PUMP applications in the residential market?
    r404a
    PA/DE area
    I think Variable speed fan really saved the heat pump around here.PA philly area.
    It's NOT the BRAND,it's the company that installs it!!!!!
    Rapid City, SD
    Absolutely! I don't think anything else should be sold but variable speed anymore (but I know that's a long ways away from happening).
    Are you familiar with the comfort-R settings that A/S and Trane have? It cools the coil down to remove humidity then ramps up later if needed. It also can do that in heating aswell to help cure the problem of "the air isn't hot enough coming out of the vents when the heat pump runs".
