Results 1 to 13 of 17
Thread: Communicating wire
07-18-2011, 04:51 PM #1
- Jul 2011
- 8
Communicating wire
Misubishi split air conditioing system model PK30UK.
The 12 volt polar comunicating wire from the inside unit to the outside unit, what is the amps on this line it is not marked on the wiring diagram.
Stu
07-18-2011, 07:26 PM #2
Does it
say anything in the installation manual?
07-18-2011, 08:38 PM #3
- Oct 2009
- Rhode Island
- 72
ill just say ten wrap
07-18-2011, 09:48 PM #4
- Jul 2011
- 79
isn't that dc? not too familiar with misubichi's, I may even sound like a moron here...
I hate mini splits....
07-19-2011, 04:37 PM #5
- Jul 2011
- 8
Lets be clear
On the split system I need to know the amps on the communicationg wire going from the inside unit to the outside unit going to a small circuit board.
It is 12 volts but what is the amps 500 mA or 1 amp.
Stu
07-19-2011, 05:12 PM #6
Mitsubishi
is very specific on what size/type wire they want for their systems. It should be in the installation manual what to use.
07-19-2011, 09:25 PM #7
- Jul 2011
- 8
It does not!!
Stu
07-20-2011, 07:57 AM #8
Are you
sure this is the correct model #? Closest thing I see is PKA-A30KA.
07-20-2011, 12:12 PM #9
- Jul 2011
- 8
maybe that is the # of the inside unit but the line going out, I'm sure is right.
I could send the wiring diagram by email.
Stu
07-20-2011, 02:42 PM #10
The required
or recommended wire size will be in the instruction manual. Give me the model # of the outdoor unit and maybe I can help you find it.
07-20-2011, 04:22 PM #11
- Jul 2011
- 8
Hello
What is Apms or do you not know of do you want me to send the wiring diagram,
07-20-2011, 04:34 PM #12
Tha amp
draw is very low. But since the wire is used for communication, they are very specific about the size. Get the model # of the outdoor unit, and I can do some research.
07-20-2011, 06:03 PM #13
- Jul 2011
- 8
Do you want the wiring diaagraram
Do you want the wiring diagram of the outside unit, I'll send it to you by email
stu2
