Results 1 to 4 of 4
    Oct 2005
    Omaha, NE
    Thanks all for the advices recently on humidifier installation.
    I installed an Aprilaire Humidifier 550 this weekend.
    A useful link is here:
    http://www.myhvacparts.com/Full%20Hu...0Education.htm
    Most of the installation is straightforward. The only tricky part is the 120V wiring for the Humidifer Transformer:
    - The A50 relay (the previous contractor installaed it) was not functioning. from my reading and talking to installer, they hate the A50 relay.
    - I have 1991 Tempstar furnaces (x2), and it was a challenge to find the 120V to hook up the transformer. I wired the 120V circuit to a "switched" terminal, which means the transformer is powered only when the blower motor runs. In my case (for those familiar with Tempstar circuit board), I used a voltmeter and watched the furnace go through a cycle and probe to see which terminal turns on with the blower on. I found #1,#4, #5.
    #1 & #4 are "upstream" from the blower circuit (#5) so I removed the jumper wire from #1 and #4 and make new connection with a winged nut. (They adise not to wire directkly into the blower motor circuit and I am not sure why not because the transformer draws very little current anyway).
    I also took (alot of ) time to clean and vacuum the burners and heat exchangers... about a cup of black soot and tar removed. I used a 1/2" hose (clear type) attached to a vacuum machine to clean the furnace.
    ANYWAY WORKS GREAT!!!
    cn
    Omaha NE
    This is not a DIY site (link below), so please post accordingly.
    Thanks for your understanding.
    (we can't help DIY, due to site rules )
    Bartlett, IL
    cn
    Omaha NE
    Whoops, you just flubbed that one up by tying it into the blower, now it's gonna be producing back emf. It'll work for a while like that, but soon you'll be replacing that blower motor, hope they have em on sale.
    That's not the only thing that going to lose it's smoke!
