Results 1 to 8 of 8
07-17-2011, 10:34 PM #1
New Guest
- Jul 2011
- 3
return,filter,comfort air blower,coil then the supply ducts!!!!!
My apartments central ac when I went to change the filter I see the coil is before the comfort air blower.has anybody ever seen ac setup that way before I confront my landlord.I was wondering why my thermostat would never satisfy!
07-17-2011, 10:49 PM #2
If its a heat pump its supposed to be that way.
07-17-2011, 10:57 PM #3
New Guest
- Jul 2011
- 3
Nope its not a heat pump
07-18-2011, 12:01 AM #4
Is it an electric furnace?
Alot of lowball contractors will put it straight AC with an electric air handler, using the heat strips as the only source of heat.
If so, it's normal.
Is there a natural gas line or an oil tank hooked up to the indoor?"Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
07-18-2011, 04:15 AM #5
New Guest
- Jul 2011
- 3
It's straight a.c. ,I have steam heat from a boiler in the basement.I seem to think if I'm right that they put it in backwards due to space restrictions and changed the direction of the blower motor.no access hardly if blower had to be changed you would never get it out .Maybe they had to put it in like this so they could connect the line set to the coil?
07-18-2011, 05:55 PM #6
Sounds normal.
You have a steam heating boiler for heat.
Since you aren't using the "furnace" for moving air for gas/oil heat, it doesn't have a heat exchanger.
The only issue with a coil on a return side, is if it did have a heat exchanger.
The unit that does the cooling is typically called an "air handler", and is a standard straight AC unit.
Again, it doesn't really matter what side the blower is on, it matters what side the heat exchanger is on, and since you don't have a heat exchanger, it doesn't matter."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
Dad adjusted
07-19-2011, 01:16 PM #7
most blower coils are set up with the blower assembly after the cooling coil.
07-19-2011, 03:02 PM #8
We just picked up a bunch of tire stores, and every AC for the waiting room has return, filter, blower, and AC coil.
You can't change the blower direction without pulling the housing and pointing it the other way. Reversing the motor won't do it. Just an fyi.[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
