Results 1 to 2 of 2
    Oct 2002
    chicago
    Frown
    customer called about above furnace.would not come on.new install by another contractor. air worked in summer,but no heat at start of season.found fuse blown on board.found t-wire was pinched where it passed through the ceiling to apartment t-stat.replaced wire and t-stat.it ran for a week.now customer says fuse is blown again.I don't work much on fridgidare units.is there something I should be looking for,other than overt one. model fg6rk 096c-16b thanks taunch
    SE Michigan
    You have a short on the 24 vac side. Get out your meter and track it down.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
