Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 44
Thread: w/i
  1. #27
    Apr 2005
    Central California
    I don't care WHO makes it, I need a couple hundred pounds of it........
    FAST!!!!!!!
    What flavor?
    Only Chuck Norris can slam a revolving door
  2. #28
    Quote Originally Posted by mr kev View Post
    What flavor?
    In the past 2 weeks, I've gone through hundreds of pounds of 402a, 22 and 404a.
    Not to mention a bit of 134a and 410a.
    Just depends on the flavor of the moment.
  3. #29
    Jan 2010
    Do you have to keep records of that ?
  4. #30
    I write detailed invoices on every job, fill out EPA paperwork on every usage and do twice annual inventory.
  5. #31
    Jan 2010
    [QUOTE=jpsmith1cm;10797412 fill out EPA paperwork on every usage
    So you have to report leak rate ?
  6. #32
    [QUOTE=VTP99;10799052][QUOTE=jpsmith1cm;10797412 fill out EPA paperwork on every usage
    So you have to report leak rate ?[/QUOTE]
    Sorta...
    We have recorded total entrained charge and we assist the customers in monitoring leaks rates and keeping leak rates low.
    Our largest customer has one of the lowest total leak rates of any supermarket chain in the country at around 6% of total entrained charge.
  7. #33
    Jan 2010
    So if i understand you correctly your total entrained charge is for all racks.
    I read were EPA is pushing for lower leak rates. At 6% i don't see that being a problem for you.
  8. #34
  9. #35
    Jul 2000
    Treasure Coast/Florida
    I participated in a nationwide leak rate survey of supermarket chains conducted by the Food Marketing Institute (FMI) back around 1987. As I recall we were at about 31% for 65 stores and the national average was 35%.
    Strangely, I think I read recently the average today is still up around 35%. Is that true, or am I having those flashback attacks again?
  10. #36
    Quote Originally Posted by icemeister View Post
    I believe you are correct. 35% is about the average.
  11. #37
    Jan 2010
    35% sounds like a lot of lost money for 50 pounds or more systems.
  12. #38
    In a boiler room
    So is this leak rate per year?
    So at 35% leak rate a 100 lb. system would lose 35 lb a year?! Or am I not understanding this?
  13. #39
    Quote Originally Posted by chuckcrj View Post
    You've got it.
