Thread: end clearances
    Aug 2010
    end clearances
    Does any body give end clearances for Howden WRV 255 and maintenance manual. As nothing is available on the net regarding Howden.
    Jul 2011
    I have various howden manuals but you need to know what type of thrust bearings you have. If it's tilted pad thrust bearings then the end clearance will be more.
    Not in Iran
    never heard of Howden., u should post a IOM
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
    Jul 2011
    Howden compressors are very common in the oil, gas, and chemical industries. In my opinion they're the best refrigeration screw compressor on the market with Mycom as a close second. I've used Howden compressors in just about every refrigeration application, from R-22, Ammonia to Propane and Helium. I've also used them to compress natural gas being supplied to gas turbine generators and compressing sour gas with high concentrations of H2S. They can take a beating and keep on running.
    I don't have an electronic IOM but if I have time I'll scan one of the old fashion manuals.
    Aug 2010
    Yes it is sleeve journal with tilted pad
