Results 1 to 13 of 17
Thread: Frost Forming
    Oct 2005
    Hi, I have a Rudd 10 Seer unit with Heat Pump. Around 5 months ago I replaced my outdoor unit. When I turn on the heat I now notice frost building up on one of the pipes on the Air Handler (inside unit). Is this any reason for concern? If so, what should I do?
    Thank you all in advance!
    Oct 2005
    it almost looks like ice building on the pipe in the unit inside my house. Any ideas?
    Nov 2000
    Upstate, SC
    From the amount of information you have given, I can not be sure, but yeah, I do think it is cause for concern. If I were you, I'd call a local contractor and let them take a look at it.
    Bobby
    Oct 2002
    Yo.... Here!, I'm right here..
    shoot it!!!!!
    or shoot the installer!!!!!!!!!!
    jes kidden call the installer monday
    it may be working fine depending on where you live and the ambiant
    Oct 2005
    I live in New Jersey. The outdoor unit is new, around 5 months old. It worked fine all summer. But now with the heat on the air handler inside my unit has this ice forming. Does it have anything to do with the new unit I put outside? I've never noticed this before I changed the outdoor unit.
    leland nc
    is the unit going into heat mode. call the installer and have him look at it. may want to put it into emergency heat till he can get there . this way mo damage can be done to the outside unit since it will not run this way if wired properly
    Apr 2002
    Phoenix
    So, the air temperature outside has approached freezing, and the big pipe to your indoor unit is now frosting up?
    Call the installer to look at it and make sure everything is OK (a good idea since it has switched to heating mode and things work differently in this mode.) Your previous heat pump was probably doing the same thing, but since you had not pumped a bunch of hard earned cash into it recently, you never looked at it closely. The (big) pipe needs to be insulated all the way, otherwise it drips condensation (or melting frost) over parts of your house, causing water damage or mold or something bad.
    Get your system looked at, and get the problem fixed.
    Oct 2005
    I would check the filter, you should change it every season. You might have a bad reversing valve. Good Luck!
    What was the name brand of the old h/pump and did they change the wall thermostat? Questions ????
    Jan 2005
    Crooksville, Ohio
    [QUOTE]Originally posted by ooo
    I would check the filter, you should change it every season. [/QUOTE
    NO. You should change it much more often then every season. I tell my customers to check their filters on a monthly basis.
    All Seasons Heating & Cooling
    Sounds like it is still cooling.
    o/b config doesn't ruud use "B" ?
    Oct 2005
    [QUOTE]Originally posted by redhawk
    I agree with you. But most homeowners wont check every month. If you get them used to seasonal changes that would be at least three per year.
