Results 14 to 16 of 16
    Boy, you sure did save alot of money.
    So much that now you don't have any left.
    A real contractor would have had it repaired for less then the damage you caused.
    Go else where and continue to replace parts for no reason if you want.
    If your smart, you'll call a service company and get heat for that 1 year old, if you care enough.
    Jul 2000
    NW IL.
    This could well be one of the Colemans on the recall program. You should check http://www.cpsc.gov and see if it is listed.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
    Make sure the induced draft blower on the right side of the furnace is running when it calls for heat.
