Thread: Spacepak input
10-21-2005, 05:05 PM #1
Hey, does anyone have any input on price or quality on spacepak units? What are the pluses and minuses? I know about zero about them, any info about them would be good.
Thanks in advance -
~MX
10-21-2005, 07:01 PM #2
- Dec 2003
- Location!, Location!
- 929
They're $pendy, but every customer we have that gets spacepak loves it. I haven't done one of the square duct ones yet- I'm kinda bummed of about the change as we have 5-10 termination kits from the round still around, and not enough round plenum & fittings for any use.
In our experience:
Pros- fast install with minimum wall tear-up-
(1-2 days for a 20 terminal/2story house).
easy to calculate size
don't need their condensing unit
works well with the aspiration principle
people usually ask for it-no hard sell.
Cons- one return(by design)
can't really do much else with the airflow
(humidify,hi-efficiency air cleaner)
$pendy
be sure to schedule a drain check every spring
be sure to use a secondary drain pan
lotsa 4" holesaws-add 3 of them into the quote
don't use the regular duct tape on them-get hi- strength 3"
They're nice systems for the house that has hydronic heat- I wish they'd get an approved setup for more than one return. Other than the annual c&c(incl drain), there's been no service issues. We removed one from the dunham-bush era, I think it was 25 yrs old-weighed a ton-mostly steel evap w/copper passes only. The coil had multiple leaks and it was a better answer to replace the airhandler. We're in northern IL, so I don't know if there is any difference in other areas. They do make a hydronic coil for them for heating, I haven't done any of those. Find the largest distributor in your area and go see all the components. If the guy is a good dealer, he can give you more info. Their manuals are very straightforward, and if you follow their instructions, you'll be fine.
edit: here's the link:http://www.spacepak.com/
[Edited by rimek on 10-21-2005 at 07:06 PM]
03-28-2006, 10:47 PM #3
- Mar 2006
- 5
look here
XXXXXXXXXXXXXXXXXXXXX or XXXXXXXXXXXXXXXXXXXX
>>>edit...
Regardless of expertise this is NOT a DIY site.
Please review the site rules before further posting.
We look forward to you cooperation.# 4 Advertising of Web Sites and Products
"Advertising of web-sites and products is not accepted on this site - so don't do it."
[Edited by Jultzya on 03-29-2006 at 12:25 PM]
03-28-2006, 11:00 PM #4
You can get a return box from spacepack.
