Results 1 to 4 of 4
Thread: Finding flex-duct obstruction
10-20-2005, 10:49 PM #1
- Oct 2003
- 60
I had an attic space finished, and part of it involved routing existing 4" insulated flex-duct from the first-floor vent fans over and around joists. Now the fans appear to be fully obstructed.
Is there any trick to finding how far into a 25-foot run of flex-duct is an obstruction? Nobody I talked to had any ideas but there must be something better than ripping up floors and drywalls to expose the whole run?
10-20-2005, 11:06 PM #2
- Jul 2004
- Poughkeepsie, Ny
- 631
Check where you monkeyed around with the duct work. If it worked before it is probably something you've inadvertantly done. Also, there are two sleeves in insulated duct work. I had a cust. do the same thing you're talking about. The insulation at the connection slipped into the duct and blocked off his return to the a/c.Originally posted by dbooksta
Is there any trick to finding how far into a 25-foot run of flex-duct is an obstruction? Nobody I talked to had any ideas but there must be something better than ripping up floors and drywalls to expose the whole run?Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
-Robert Green Ingersoll
10-20-2005, 11:26 PM #3
- Nov 2000
- Waco, Texas, USA
- 6,153
Do you have a house cat and have you seen him lately?
10-21-2005, 07:03 AM #4
Professional Member*
- Nov 2004
- SW FL
- 5,249
Valued Instrument
You meanOriginally posted by dbooksta
you Actually have flex duct that is not entirely accessible?
Use a Tape Measure!
Also, Reminder:
There are two ends to each duct.Designer Dan
