Results 1 to 7 of 7
    Janesville WI
    Here is the problem, when I try to override an AO it adds 2 00 to set point if I try to back space it leaves 0.00
    I know it is in my PC because I can make override changes at work station with no problem.
    The problem is only in the override set piont changes other set point changes work fine
    PC has windows xp professional with service pak 2
    Besides fixing this with a five pound mall this one has got me.
    Feb 2005
    have not played around with v16, but sometimes back if I remember correctly summit took some settings from pc's windows':
    control panel ---> regional settings and language options ---> customize
    look in there, may be your problem.
    Janesville WI
    I still like the smashing it with a hammer I would use that ulgy face with the red HVAC hat on as a target, what does the rest of it look like I may need a bigger target and why does it have this big ass smile on his face when Im so pissed off
    Feb 2005
    I know exactly what your talking about. However I have no idea what causes it. The problem is not only with v16. I have had it with v12,14,15,16 with xp,2000p,win98.It comes and goes. Sometimes just restarting the computer fixes it.
    People will think your crazy when you ask about it. Never asked Trane-St.Paul why?
    If I find out I'll pass it on.
    Janesville WI
    Thanks smokey, I hope that when I come in and try it in the morning this will be gone but I dont think it will be this simple
    Janesville WI
    I was just told how to fix this, here is what I was told to do when you hi-light point that you are over-riding hit or push insert on key board. I will believe it when I see it in morning but coming from the source I have I should believe it. this guy is GOOD and his memory is like a womans he doenst forget anything
    Janesville WI
    I had to toggle it back inforth a few times but it worked and proble is gone for now.
    Thanks MD
