Results 1 to 13 of 20
    Jul 2011
    compressor issue when charging
    so i am a certified tech and was working on a 10-15 year old payne unit suction pressure was 40 so i added r-22. 8 oz. vapor. unit taking refrigeranty at a very slow rate so i added 8 more oz. in a liquid 4 at a time slowly. this got the suction pressure to about 75 and all of a sudden compressor makes intermittent wierd sounds sending the pressure up and down between 75 and 120. then compressor just stopped working. disconnected power and am hoping i just flooded it and in the morning it will be fine. what do you think???
    May 2010
    Oxford, UK
    Did it go "ngung ngung ngung PATCHEWWW"? and then repeat a few times before it died?
    And then go "HMMMMMM click"?
    Feb 2011
    Georgia
    if its recip comp may be the one way valve letting liquid back through
    South Dakota
    Quote Originally Posted by monkeyspanners View Post
    Thats good diagnosic info there LOL
    My coworker always tries to imitate sounds-usually he ends up getting mad at us when we make him repeat it about 4 or 5 times.
    just thought it beared repeating
    Mount Airy, MD
    Bahahahahaha
    Mount Airy, MD
    And why are you not a Pro here???
    Jan 2005
    southeast
    Did you ever check the HIGH side pressure while it was running. There may have been a restriction or a TXV power assembly loosing charge and you were overcharging it causing the head to climb.
    Mount Airy, MD
    Just remember the DIY thingy here guys
    Jul 2011
    as far as sound effects go you nailed it. good description... i take it you may have heard that sound in your day. any idea what that is/ how to avoid repeating? forgot to mention that i went back today and compressor workede and system ran fine.
    Dec 2009
    northeast pa
    Quote Originally Posted by stemps22 View Post
    Let professional charge units. liquid slugging is the term.
    Jul 2011
    yeah man i am a pro with more learning to go. (2 years schooling and a little less than a year field experience) thanks for the term information, however i'm curious to know what actually happened. i work for a small company and would like more feedback than the one other tech had to offer thanks
    When you were in school, they taught you about pressure temperature relationship and some measurements that are taken by using BOTH a pressure AND a temperature.
    Go ahead and start using those readings.
    As to what actually happened, you probably over-charged it.
    Hermetic reciprocating compressors are refrigerant cooled, so a little liquid isn't likely to hurt a healthy compressor.
