    Jul 2011
    How to light the Thin-Boy Pilot light
    Hello,
    I just moved into a house and it has an old blue Western Thin-Boy furnace. It was on and worked when I moved in, but I had to turn off the gas to install a dryer. Now the pilot is out. I can't see where it actually is. I think it is way inside. I tried sticking a match on a wire following the gas line, but I can't see what I am doing. Perhaps the pilot light is inside the big tube where the gas goes into the furnace (about 1 foot long, turning up at the end into a 2" openning)?
    Does anyone know how to light the pilot light on a Thin-Boy?
    Much appreciated,
    Dan
    Atlanta, GA
    Also, could you please post some pictures of the furnace itself, and of the inside? I like seeing old HVAC equipment still in use.
    Sorry we can't help you with that. I'd guess this thing is rather long in the tooth (ancient) so it probably would be wise to have a pro check it out and if sound, show you how to light it.
    Jan 2010
    Athens GA
    I've seen and worked on a lot of differant furnaces but I have never seen a "thin boy".
    Would it be possible to take some pictures of it(the more the merrier) and post them here?
    Its a long shot but if we see it we might know how to light the pilot.
    I love old equipment.
    Jul 2011
    Quote Originally Posted by REP View Post
    Well, I'll try... It is probably 1950's, when the house was built. It is bright blue!
    Here's the only thing I found online (from a few years ago):
    http://www.justanswer.com/hvac/1wu1e...eed-light.html
