Awwww now, ya'll scared him off.
"FIGHT CRIME: SHOOT BACK"
Re: Jump a furnace...
Originally posted by 2hot2coolme
It would probably be easiest if you lay it down...most furnaces nowadays are around 40" tall, you might be able to jump a Rheem or Carrier 80% vertically...
But if you miss.. OUCH!
RSES Certificate Member Specialist
Southwest Regional Association of RSES Secretary, 2017
Is that run the thermostat and jump the furnace? And oh yea, barefeet or sneakers?
Sometimes yah have to pole vault, those older ones were too high to hurdle
http://www.ductstrap.com/
i think he means "jump"er. i would take all of the wires in the furnace and splice them together, you will need a big wire nut. turn off the power before you splice, you don't wanna blow the fuse.
FILL OUT YOUR PROFILE!!
Originally posted by jonathan1979
I am a Tech I want to make sure how i'm thinking to do it is right
A tech that can NOT wire around a simple stat, Hummmmmmmm.... ARE YOU SERIOUS?
a short piece of wire with alligator clips on either end
hey Julz, thought you might like to know I made my 300th post on you.
Thanks pal!
Now where did he say he was an HVAC tech?
He might be some other kind of tech.
Maybe some kind of computer tech, or surgical tech, or fast food tech.
See, there you go.
Always jumping to conclusions.
i used to use my old schwinn for jumping them , to damn old for that now.
- You may not post replies
- You may not edit your posts
Forum Rules
