    Ohio
    One of our techs is working on an automated logic system with a main board #S6104. He is concerned that the error lite is blinking. Does anyone know what this means? Is it an active alarm?
    TIA,
    Jogas
    May 2005
    Left Coast
    The "Error" and the "Run" LED's on the S6104 show the control module and network status. Differently timed flashes mean different things. For example, if the Run LED shows 14 flashes per second and Error LED shows 14 flashes per second, alternating with the Run LED...there is a brownout. If "Error" flashes 4 times and the "Run" flashes 2 times, then there is 2 or more devices on this network with the same address. ETC. ETC.
    I would just turn off the power on the module and power it back up. That should do the trick. Flashes on the "Error" LED are much better than a constantly lit "Error" LED.
    Ohio
    Thanks DDCPWC,
    Is there an online source for all the codes that we may see?
    Jogas
    May 2005
    Left Coast
    I don't think there is an online location for these. The owner should have received one with the O and M's, but I am assuming this paper work is not available. If you give an email I will send you a S6104 technical manual.
    Ohio
    ddcpwc,
    Thanks a million.
    Send to "jogas@cox.net"
    Jogas
    Jan 2002
    Fort Worth\Dallas, Texas
    could you please send me one also. My email is in my profile.
