Thread: need help
07-11-2011, 08:50 PM #1
New Guest
- Jul 2011
- 1
need help
Does anyone know how to find the size of an old whirlpool unit model #NCAB029AB02?
07-11-2011, 09:37 PM #2
Look at the compressor model number.
Its probably 2.5 ton
07-12-2011, 12:29 PM #3
- Aug 2010
- Greenwood, IN
- 31
Generally sizes can be determined through the model number. Somewhere in the middle or at the end two digits represent unit size. With your model number I would interpret it to indicate about a 2.5 ton unit.
07-12-2011, 01:51 PM #4
Here is a trick I learned.
If you have no idea what size a unit is get the RLA off of the compressor.
Then go to some new product data sheets and compare the RLA of a new unit.
For example. You have a unknown compressor with a RLA of 15.5 A. Go to Carrier, Trane, Lennox etc. new product data sheets.
Under electrical it will give you the RLA for the compressors of different size units. For example a 3 ton system has a compressor of 16.6 RLA. And a Two ton system has a RLA of 14.9 RLA. Then it is a pretty good chance to think that you have a 2.5 ton system.
07-12-2011, 04:08 PM #5
If you get the rla..you can probably get the model # too.
