Page 3 of 3 FirstFirst 123
Results 27 to 32 of 32
  1. #27
    Tyler TX
    I would agree with carnak on this, the longer run times and fewer start cycles would be more efficient. I would also consider for the same reason that the furnace would probably last longer due to less stress on the heat exchanger.
    HVAC Contractor, Tyler Texas.
  2. #28
    Apr 2002
    If it is a comfort issue then forget the two stage and get a rheem mod
    http://www.ductstrap.com/
  3. #29
    Feb 2005
    The 75,000 is more than you need But so is the 50,000
    input on the two stage 80% of the time.
    Get my point?
  4. #30
    Feb 2005
    two speed
    Comfortmaker also makes two stage with two speed inducer and two stage gas valve, not modulating. (Model C9MPT050F12)
  5. #31
    maybe they say that for a reason.
    so people wont think that they should down size their furnace because it is "more efficient" two stage.
    Sometimes there are compounding complexities of multiple variables that are not intuitively obvious
  6. #32
    Apr 2002
    I think a lot of two stage out there hardly ever hi-fires.
    The furnaces seem to be over sized, some times intentionally to get enough air for AC.
    The two stage is like a safety net for oversizing.
    I guess my reason for saying this was the most common furnace sizes I sold in Canada were 60 & 75 MBH, and designing for close to 100F temperature differential.
    I see all kinds of posts in here on furnaces 100 & 125 MBH, in a much warmer climate.
    [Edited by Carnak on 10-22-2005 at 03:19 PM]
