Results 1 to 13 of 32
    Oct 2005
    Hockessin,DE
    How much more efficient are 2 stage units compared to standard units?
    What's the usual payoff period for them in a moderatley cold area like Delaware
    2 stage furnaces are for comfort, there is no efficiency gain.
    Oct 2005
    Hockessin,DE
    thought that was the case with variable speed
    i was told by contractor that 2 stages give you a good boost in efficiency without upgrading to the next AFUE.
    he also said the variable speeds are the ones that are mostly a "confort" factor than efficiency
    May 2002
    Colorado
    Contractor is wrong.
    Oct 2005
    Hockessin,DE
    ok may be my question should've been...
    is there a saving on "heating bill" in upgrading to a 2 stage.
    No saving,just comfort,for two stages.
    Variable speed fan ,comfort and likely some savings on electric for the fan.
    Aug 2005
    Some people even say that you lose efficiency on low fire.
    eventu rerum stolidi didicere magistro
    Re: thought that was the case with variable speed
    If it gave an efficency boost, then it would have a higher AFUE rating.
    May 2002
    Colorado
    Yes. Excessive combustion air reduces efficiency.
    Feb 2005
    Two Stage
    If a home has a heat load net 50,000 btuh, that means that amount of energy is needed in extreem conditions ( 0 degree
    and maitain 75 to 80. More than 80% of the time you do not see
    those temps in New England. (I live in Mass.)So if you have a two stage unit which is 40/60 input it only makes sence to me that running on 40,000 btu input would be a very good thing.
    PA/DE area
    In Delaware we found that it makes the home alot more comfortable,due to longer run times,not the BIG BLAST and then OFF and then on again.Some of the places in Wilmington we have taken out the eletric baseboard in some rooms that needed them with the old heaters.
    It's NOT the BRAND,it's the company that installs it!!!!!
    Indianapolis, IN
    May be I am wrong, but the only scenario I can see how 2 stage can provide boost in the efficiency is in combination with zoning system, when small zone calls low fire.
    Feb 2005
    I Disagree
    If you have two same 92% furnaces side by side and the single stage is 50,000 input , The two stage is 35/50 input you tell me which one will be more efficient operating for a season. ( More efficient meaning will burn less fuel for that
    season)
