    Just wondering---What software do you use to access network from laptop,is it Network Service Tool?What adapter do you use to go from USB to their RS485 and where do you connect to the bus?
    Jul 2005
    Wisconsin
    You can connect to it with Service Tool, or Comfortview. You can wire the comm bus to a phone jack, or connect right to the 3-wire bus using a signal converter. B&B Electronics makes several models that you can order online. Most of the ones I have ordered required a serial port rather than USB.
    Thanxx
