    mini-Split heap pump in DC area--dos it work in winter?
    I am considering installing a tri-zone Mitsubishi mini-split ductless system in a townhouse in Washington DC. I'd like to know 1) if the mini-split heat pump is adequate in this climate, and 2) is it a lot more expensive than gas furnace? 3) is this a much cheaper solution since no duct work is required? Thanks for any advice.
    Winston-Salem NC
    Dunno.
    A local contractor should be able to explain the pros and cons, tell you the possibility of a heat pump and give you data between the cost of one versus another.
    Grottoes VA
    It will work just fine in the DC area, you might need some sort of back-up source of heat when the temps drop into the single digits. That doesn't happen very often here.
Tags for this Thread
