Results 40 to 43 of 43
Thread: Trane vs Carrier (heatpump guru)
10-29-2005, 09:44 AM #40
- Oct 2005
- 34
Hi dash, I don't know what size system we currently have, all the labels are ruined (faded from the weather), you should have seen the puzzled looks on the hvac guys, can't read a thing of them...Both companies did a manual load. I don't understand why one recommends a 2 Ton and one a 2.5 Ton...I guess this is the way the matched system are designed.
10-29-2005, 04:03 PM #41
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
Nope one is correct and the other is incorrect,or worse yet ,they are both wrong.
If your in a humid climate you really don't want to over size.yopu can do a calc. at the RED tab above for a small fee.I'd ask each to check their numbers .
10-30-2005, 09:21 PM #42
- Oct 2005
- 34
What do you think about this system?
Since I am running out of time trying to find the right contractor I will order this system tomorrow...Trane XL14i...TEE3F31A100A..BAZHTR1410..4TWX4024A1..14 SEER..2 TONS..this was the most expensive bid I received, and the biggest company I had contacted, but the rep. was the only person to check out the wiring and take a look at the breaker box and suggested to bring in an electrician. What do you think?
10-30-2005, 09:27 PM #43
Banned
- Aug 2002
- 18,836
I'd make sure the load calc is correct or the contractor is on the hook in writing,like one brands 100% satisfaction guarantee,if it's wrong.Originally posted by dash
