Page 1 of 4 1234 LastLast
Results 1 to 13 of 43
    Oct 2005
    Wink
    heatpump guru...thank you for bringing up Carrier...I am currently comparing Carrier against Trane, and I must say the Puron is making me wanting to by a Carrier system, nobody can beat it....any thoughts out there? Ya'll are so smart, great thanks to ya'll...
    Jul 2002
    Zelienople, Pa
    Trane has 410A heat pumps which are the same.
    Don't compare brands, but installing companies.
    That will make the difference!
    Oct 2005
    I am also comparing the few contractor/dealers we have in our area; The few ones the manufactors recommended. There aren't many "Pros" in our area.
    Nov 2000
    Eastern PA
    See if you can get "selfemployed" to respond. I don't know if he is near you, but he is in North Carolina.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Oct 2005
    allright, I'll try..all help is greatly appreciated.
    PA/DE area
    Trane makes a good heat pump,and I know many think all I sell is Carrier,WRONG I sell what is best for the job. My father has XL16i with XV90 and father in law has 3 XL1800.I like the Infinity setup,I could have gotten either and no cost for my own home and I took the Carrier(I gave my Ground source to the vo-tech to train the guys on it)I think the XL or 38Y ?? are both fine products, some people it is better to have a roof to keep stuff out of outdoor units,Trane some like the Infinity set-up.The variable speed is a MUST!!Trane model numbers for outdoor 410a(PURON)begin with the number four,R-22 or FREON start with the number 2.
    It's NOT the BRAND,it's the company that installs it!!!!!
    Oct 2005
    I looked into getting an Infinity installed but the Salesperson said it is to big for my little house, I would need only a 2.5 heatpump and the Infinity system comes in 3 and 4 ton. So he has recommended the Perfomance series, Model 38 YXA and Fan Coil FV4.
    PA/DE area
    Both good you can put in Thermidistat control with that set up,SWEET. but a Trane 4ttx4030\4TEE fan coil is a good product also.They are both BIG on the outdoor side so make sure you can fit it or hide it.As we said GOOD PRODUCT does not count installed poorly. Please change lineset!
    Oct 2005
    Hey, Yellow Dot...GitErDone...hahaha...only somebody from N.C. can say that....You are not so far away from me....can you recommend a reputable installing company...since you know that will make the difference and I totally agree with ya'll.
    Jan 2003
    The Carrier Infinity in a 3 ton will run at 50% or 1.5 tons most of the time, and it will not be oversized. Since they are two stage systems, there is no point in manufactoring them in half ton systems.
    PA/DE area
    Peton speaks the TRUTH,
    Nov 2000
    Upstate, SC
    That is what I was thinking when I read that post too. I think some contractors are just afraid of the new technologies and try to stay away from them as much as they can.
    Bobby
    Jul 2002
    Zelienople, Pa
    Where do you live?
