    Oct 2009
    york. pumping system down
    I need to pump system down but doesn't have standard Valves. I think there packed angle Valves.I took off nut to close high pressure side and then try to pump down but it would only pump down so far. I left nut on low pressure side wasgoing to take off nut to close Valve but never achieved complete pumpdown. Any ideas would be appreciated e.
    Jun 2006
    New Jersey
    Quote Originally Posted by jay729 View Post
    How long is the line set? And you sure you are closing a liquid service valve and not a discharge?
    Oct 2009
    Liquid line is closed. Lineset bout 20ft.
    Jun 2006
    Are you trying to recover the refrigerant or pump the refrigerant into the condenser?
    Certain York condensers had piercing needle valves that will not allow the user to pump refrigerant into condenser.
    With those types you must recover refrigerant into tank or perhaps use a pinch off tool.
