Thread: In conc. Slab
    Aug 2005
    Question, has anybody out there installed supply duct in conc. slab latley, in a home.
    It's been sometime sence we have installed duct under slab.we have a gen. contractor that wonts us to install them in that way. I told him its going to be expensive.
    its in the pacific N.W. where it rains a lot.
    my question is what is the insulation requirments for under slab duct.
    the last time we did one we used just spunstrand duct.
    and I know insulation req. have changed.
    I won't to be prepar before I go to the building dept.
    Thanks for any information.
    chicago suburbs
    i just did a house addition last month like this. no insulation...just pvc coated spiral. easy money....get your shovel ready.
    FILL OUT YOUR PROFILE!!
    Aug 2005
    PVC coated spiral pipe. OK I'll try that.
    Thanks a lot tinner!
    Huntsville,AL
    under the slab!
    needs egg sized gravel over geofabric to drain away the moisture.
    I would use pvc -- coated pipes are hard to have joints properly coated in the field.
    check my prior posts for a mfgr of thin wall plastic -- they started by making pipe for lab hoods --
    chicago suburbs
    the fittings and couplings are PVC coated as well. i used United Duct seal (oil based)to seal all of my connections. this is a whole section of ductwork and special fittings made exclusivley for underground. it's not cheap...10'of 12" spiral was about $75.00. 6" adjustable elbow was about $15.00. this stuff is heavy gauge metal. it will obviously get wet under ground that is where the coating comes in.
    they back-filled with regular pea-gravel. then compacted it down. 4" of concrete after that and you're done.
Comfortech365 Virtual Event
