Results 14 to 17 of 17
10-15-2005, 09:13 AM #14
With that reasoning, only a few select customers should buy high eff a/c's.
10-15-2005, 01:18 PM #15
- Oct 2005
- South/East Michigan
- 24
Just wondering... "if" we are discussing moving in 4-5 years (moved in this house in 1999), does a newer furnace have a good return on investment? For example, if I paid $2000 (just a fake figure) on a furnace, and moved... would I at least get that back when I sold the house based on it's a "newer furnace"?
Oh, and my house is a 1,100 square foot ranch w/ a basement and currently has a 75,000 BTU furnace in it... My furnace guy said that 75,000 is all that I would need... The basement is finished, so, should I take that in consideration when figuring out the BTU's?
Thanks...
Bill
10-16-2005, 03:15 AM #16
Professional Member*
- Nov 2004
- SW FL
- 5,260
Great Common Sense Advice
Originally posted by beenthere
Go with the 90% furnace.
When its time to replace the a/c, get a heat pump instead.
Designer Dan
10-16-2005, 03:53 AM #17
- Feb 2005
- 35
My thought is NO. You appraisal value of your home assumes you have a good working furnace. It's not likely you'll be able to charge more than the appraisal value. I just sold a house, and nobody cared about the new furnace. If you are in a competitive housing market, you may have an easier time selling your house when you advertise that it has a new Ultra-High Efficiency furnace that will cost 100s less to operate than a similar home.Originally posted by spacescape
