Results 1 to 8 of 8
Thread: Relay question
    Jul 2011
    Corpus Christi, TX
    Relay question
    Is a relay only used for heating or cooling also? This would be in a split residential system.
    Depending on the system it could easily be both.
    Jul 2011
    Corpus Christi, TX
    if it is for cooling then would I find it in the condenser outside or the air handler inside?
    Jul 2011
    Corpus Christi, TX
    if the relay was faulty would the compressor still run?
    May 2011
    Oklahoma
    DIY question???? Call a service tech.
    NE FL.
    Quote Originally Posted by 408-COUPE View Post
    Agreed.
    Could possibly be a start relay, if its in the OD unit. Most often you'll see a relay in the ID unit. But plz do call a professional.
    Sep 2010
    Western, MO
    What relay?
    The answer is yes, no or maybe.
    jim
    Common sense isn't very common anymore.
    Jul 2011
    Corpus Christi, TX
    I'm not a DIY, I just finished going to HVAC school at the community college and was asking a question on something that i had confused in my head. The relay question was posted because my other post has gotten no responses and so I thought i would ask about the relay.
