    Oct 2005
    Minnesota
    Question
    Hi, Just had a new Infinity 96 installed at home, but the 2nd level in the home is about 5 degrees cooler. Not sure what to (will try closing some of the vents close to the thermostat and see what happens).
    Also, the thermostat seems to be reading a higher temp than other thermometers in the house. Not sure what to do. Any advice?
    Jul 2002
    Zelienople, Pa
    Call back the installing company.
    Crooksville, Ohio
    If it was just installed, why would you not call back the installers? That would be the best solution to your problem.
    All Seasons Heating & Cooling
    Oct 2005
    I know. This absolutely floors me. I can't count the number of times I hear "that drain lines been leaking for four years", it's like "why didn't you call?"
    Oct 2005
    If the system was recently installed,It is under warranty.
    instead of quessing ,And assuming it was installed by a licensed prof. It will be covered. If you had a jack leg
    installation, Happy shopping!
