Results 1 to 13 of 29
10-14-2005, 01:41 AM #1
- Oct 2005
- 27
So, what's the best way to test a Heat Exchanger? I hear you can do a combustion C02 test, fill it up with water and see if it leaks on the edges around the chamber or smoke bomb it. What's the correct way?
Thanks...
10-14-2005, 01:47 AM #2
Simple way is by using a saltwater solution, spray it in the chamber, and take a blue flame torch to the registers and see if the flame changes colors...cheap'n'easy way but foolproof.
10-14-2005, 06:26 AM #3
Member
- Oct 2005
- USA
- 1,720
I am always looking to expand my knowledge on testing heat exchangers. This sounds like a good method. I would worry about doing damage to the heat exchanger though. Salt water?Originally posted by 2hot2coolme
10-14-2005, 06:34 AM #4
2hot2
can you explain a bit more on this technique,do you run fan, why does flame change, what color will flame be?
thanx
10-14-2005, 07:28 AM #5
- Oct 2005
- 69
Test methods are like opinions, everybody has their own best method. In the city where I live the gas company uses a co detector that is calibrated every 30 days. I personally use the light method even though I own a CO meter. Mine was over $400.00. In my opinion the water method even though reliable is very time consuming. Do you have that kind of time on a Job? I have seen on post where they sprayed soapy water into the heat exchanger and turned on the fan and looked for bubbles. Keep in mind once the inside fan comes on the plenum becomes positive pressure so I'm a little confused on the salt water method.If you have a definite large crack it is usually easily visible with light thru it and every other method Is open to opinion. What if you say it cracked and they call another service company and they it isn't. No homeowner likes bad news. So I'm very cautious when I condemn somthing. I was only questioned once and the customer told me that he had been told the same thing several years ago and his buddy who is more than qualified to do this kind of work told him the serviceman was just trying to sell him a furnace. And I was full of -hit. His heat exchanger was fine. I signed off on my paperwork that I got visible light thru the crack and the furnace was considered unsafe for use. He is still using it and he isn't dead yet. It's not my house, I can only advise.
10-14-2005, 08:05 AM #6
Professional Member-BM-bad email, server rejected
- Jun 2005
- Victoria, Texas
- 59
When checking a gas furnace for CO2, I usually disconnect the blower motor and then cycle the burners until the high limit trips. By doing this, I know the heat exchanger is hot and the metal has expanded, plus this verifies the high limit is working. I then reconnect the blower and cycle the furnace again. I check at the closest supply register with a Fluke 210. If I get a positive reading I then get out my trusty halide torch and salt water bottle. If the heat exchanger is cracked and the salt water mixture enters the supply airstream through the heat exchanger, the halide flame will turn orange. So far,after 25+ yrs of testing this way(halide torch/salt water), every furnace I "red tagged" and changed out, did in fact have cracks/holes upon visual inspection.
10-14-2005, 08:30 AM #7
- Nov 2004
- 2,923
We use canaries...but the SPCA frowns on that practice.Originally posted by heatmehot
Thanks...
With a combustion analizer you can be certain of the problem or potential problems,and what to do to fix it.
10-14-2005, 08:53 AM #8
Everythiing You wanted to Know About
Checking HXs but were afraid to ask.
Mech Acc did an excellent post on this, it is in the FYI forum, one of the best posts in there.
http://hvac-talk.com/vbb/showthread.php?threadid=73546The way we build has a greater impact on our comfort, energy consumption and IAQ than any HVAC system we install.
http://www.ductstrap.com/
10-14-2005, 08:56 AM #9
- Nov 2002
- VA
- 296
It’s All About Conviction To Professionalism
(Personal Opinion verses Professional Judgment) First and foremost, heat exchanger inspection is one of the most important professional duties a HVAC Technician is required to perform (my personal opinion). All furnaces fail, (typically the Heat Exchanger is the show stopper) it’s just a matter of time, that is a given. No homeowner wants to hear the bad news that is common sense. CO isn’t to be taken lightly http://www.epa.gov/iaq/pubs/coftsht.html
Don’t rely on here-say, the furnace vendor’s documentation needs to be carefully reviewed and more importantly understood. Premature failure is often due to inappropriate installation & setup and incorrectly sized (or installed) air distribution systems. Many other misunderstood parameters not adequately addressed will doom even the most robust equipment.
That said, I personally had the opportunity to attend a hands-on seminar given by Ellis Prach of Heat Exchanger Experts. The ACCA-National Capital Chapter in Savage, MD sponsored this event. Rather than promoting ACCA, I would personally suggest you see if Mr. Prach is scheduled to be in your area, if so please consider trying to attend.
http://www.heatexchangerexperts.com/
As for testing protocols, they vary greatly according to the exact type of heat exchanger (A.K.A. primary or secondary in high efficiency units). Each protocol has its place; it is your responsibility as a professional to know exactly how best to procedure under any given set of conditions.
This subject is the source of some heated Forum debate (which is in itself good) however owing to the delicate détente issues I (personal opinion) strongly suggest you invest a healthy amount of academic research into this subject lest you become involved it the “Heat Exchanger Scam” marketing techniques which have proven, for some in our industry, an effective revenue generator, albeit grossly unethical. Enough said.
My colleagues in other walks of life have consistently questioned me on this particular aspect of the industry, and for good cause. Please help your service area community and become highly skilled in this one facet of our very diverse industry. Residential HVAC needs knowledgeable; proficient and ethical champions, please join in and meet this challenge.
God Bless.
10-14-2005, 09:23 AM #10
- Nov 2002
- VA
- 296
Please review Carnak's URL
Thank you Carnak
and Don
and Gary Reecher
Good Job!
10-14-2005, 12:35 PM #11
The credit is all due to Mech Acc aka Gary
10-17-2005, 12:28 AM #12
- Oct 2005
- 27
Thank you all....that is a very good document. Question though....I had two seperate companies look at my furnace. One technician said my heat exchanger is leaking around the edges (water test), other technician did a combustion test and found no C02 leakage. Which test is more accurate??
Thanks....
10-17-2005, 06:09 AM #13
- Feb 2003
- Huntsville,AL
- 4,125
probably the water test is more accurate --
combustion analyzer depends upon the calibration of the meter, its accuracy at the read value, the placement of the probe with respect to the flue gas flow, the amount of flue flow
the training & experience of the tech --
but, the presence of CO is the problem
maybe your furnace design is such that slight amount of CO is drafted away --harvest rainwater,make SHADE,R75/50/30= roof/wall/floor, use HVAC mastic,caulk all wall seams!
