Results 14 to 17 of 17
Thread: PVC Adhesives
    Oct 2005
    Originally posted by tim fox
    Why can't primer be clear! I was doin' a 90%er a couple weeks ago and accidently kicked my primer can and splattered the poor people's water tank. They were cool about it but I put an insulator jacket around the water heater gratis because I felt bad about purpleing it up on them.
    They make clear primer! It's what I always use.
    Rochester, MN
    The purple primer is not needed for HVAC here.. I've never used it in the past..
    Just use the cleaner, then glue. never had problems with it.
    Apr 2004
    Bartlett, IL
    They do make it clear, and I only use it if there's no inspection, if there is... the inspector looks for the purple color on every joint.
    There is a purpose for primer and everyone should use it period.
    Huntsville,AL
    this is a two part chemical process to achive a cold weld when done --
    not worth it to stand before "the man" and but, but, but, your Honor ---
    are you going to do a quality job?
