Results 1 to 13 of 16
Thread: Pre-insulated Duct Panel
07-05-2011, 09:13 PM #1
- Jul 2011
- 6
Where can I buy Pre-insulated Duct Panel
07-05-2011, 09:16 PM #2
- Jul 2011
- 6
I do not like the idea of fiberglass in my a/c duct work . I want the insulation to be covered. why can't I get aluminim on both sdes of the duct board???
07-05-2011, 09:18 PM #3
- Jul 2011
- 6
Does anyone know what Pre-insulated Duct Panel is ???
07-05-2011, 09:27 PM #4
- Jan 2010
- Athens GA
- 1,234
What you are asking for would be VERY VERY expensive even if you could get someone to build it for you.
Aluminim is also the wrong material as it transfers heat bettwer than almost any other material.
What you should be looking for is metal ( galvenized) wrapped in insulation.This is the best of all worlds.
Of course if its installed without a manuel "D" being done it will not provide you with the designed air flow that you are paying big money for anyway.
07-05-2011, 09:32 PM #5
- Jul 2011
- 6
I don't know how much it is but it , like everything else , is being made in China . But i cannnot find it in America yet . Google up "Pre-insulated Duct Panel " it's out there
07-05-2011, 10:50 PM #6
Banned
- Jun 2005
- Winston-Salem NC
- 1,133
07-06-2011, 10:06 AM #7
- Jul 2011
- 6
I can not believe that no one has duct board with aluminum on both sides here in the U.S.. When I googled it I found at least 5 companies that make it all over the world. It just makes more sense to me to have the foil on the inside. No restrictions and no dust build up. I will have to call some ductboard suppliers and find out more.
07-06-2011, 12:05 PM #8
Banned
- Jun 2005
- Winston-Salem NC
- 1,133
Why duct board with aluminum on both sides?
Metal is stronger, the insulation is on the outside, and with proper design and installation (along with manufacture) it is just as quiet.
For a lot cheaper price than what you are looking at.
07-06-2011, 06:31 PM #9
I can, because it's pointless.
If feel like what your looking for is "kool-duct".
It has a foil facing on both sides, and is made out of foam, not fiberglass.
To correctly install this product, and professional needs to be involved.
No one uses alluminum duct anymore in a residential application."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
07-06-2011, 07:01 PM #10
- Jan 2010
- Athens GA
- 1,234
07-06-2011, 08:01 PM #11
Banned
- Jun 2005
- Winston-Salem NC
- 1,133
I do round duct in crawls and attics when possible, but inspectors tend to be a pain, as they want to see duct sealed, then want to see you seal insulation. But it is cheaper, quicker, provides better airflow when done right and easier to install.
Headroom is the biggest issue.
07-08-2011, 10:41 PM #12
- Jul 2011
- 6
Thanks hvacvegas, "kool-duct" is just what i am looking for. I'm in the Fl Keys . I want the plenium built with a covering on the inside, so it cannot collect dust.. No one does metal down here .
07-09-2011, 02:01 AM #13
Doesn't matter if it has a foil liner inside or not. it will collect dust, all duct does.
