Results 1 to 6 of 6
    Oct 2005
    The blower will not run on heat but will run in manual and on cool mode. The unit is a 1998 Bryant 373 LAV gas furnace. Any ideas? I have not gone in the attic to see if it there is a flame but I can hear the furnace click on.
    Thank You,
    David
    I don't know
    Set the t-stat to fan on for the time being (if you require heat) and call a technician.
    Running the furnace without the blower can cause damage over time - or right away if the high limit switch just so happens to be faulty.
    Apr 2003
    Welcome to HVAC TALK.
    AMD gave you solid advice... and here is some more for you to think about.
    When was the last time you had that unit cleaned and inspected?
    Now you have a problem with the unit. Fuel costs are skyrocketing.
    So why not call in a professional to repair the unit? While they are there they can clean and inspect your unit to insure a safe living environment for you and your loved ones. Not to mention, having an efficient running system could save you more than the cost of the service.
    What's your safety worth? I'm guessing more than the repair bill.
    Thanks for your understanding.
    (we can't help DIY, due to site rules )
    Jul 2002
    St Paul, Minnesota
    Thank You,
    David
    Why go to the attic? If there is flame you will feel some heat or hear it before it shuts off due to tripping on the high limit safety switch that is doing it's job. This switch is normally closed and opens when the temperature inside the furnace exceeds it's set temp. Trying to bypass it is dangerous and foolhardy so it is time to call in the experts and get a checkup of the whole system at the same time. (Not midnite, but regular business hours). At midnight I will change your limit and suggest you have a full service done. Then I go back home to bed and wonder why people don't have a tuneup at least every other year? Or know where their filter is?
    Apr 2003
    Filter, what FILTER?
    Oct 2005
    I do have service tech coming over tomorrow, and I do get my unit looked at in spring and winter. I was just asking for possible problems/suggestions so I could have somewhat of an understanding when he arrives. Thank You for the quick posts, and suggestions.
    David
