    May 2005
    Unhappy
    I have return duct 20x25 with 1" opening at the top to insert/remove standard filter.
    Was thinking about upgrading to 5" media filter.
    Would you:
    a) Install AirBear/Honeywell/Carrier/TotalLine cabinet
    or
    b) Modify duct, cut additional 4" opening at the top, rivet 4L aluminum brackets for the filter to slide in/out, fab simple cover like.
    Thanks,
    Brian
    Apr 2003
    A
    I lean toward the first choice, because there you increase chances of error with field fabrication.
    Just adding a couple of rails does not guarantee that the air will actually pass through the filter.
    I like option b ,if that means you can use a 20X25 media filter,and you put some gaskets on the down stream rails to prevent bypass air.
    What size and cfm system?
